PeterM Offline
#1 Posted : Thursday, 19 April 2007 1:56:10 AM(UTC)
PeterM
The temperature gauge on my 82 WB Statesman, blue 308 is not working. How can I test whether the problem is the sender, the guage or the wire connection? I have a feeling its not the gauge, as I replaced the 4 gauge cluster with a set from a wreckers and the problem did not change (doesn't mean the wrecker's gauges were perfect ...)
I'm really interested in the test for the temperature sender. I assume this can be done with a multi-meter, i.e. if it is a resistance / temperature pairing, then what is the resistance when cold and what is hot?
#2 Posted : Tuesday, 24 April 2007 6:01:49 AM(UTC)
to test the gauge you should be able to take the wire from the sensor and with the ignition on and someone checking the gauge short it to an earth and the gauge should start to rise if it is working if it does then your temp sesor is u/s if not then the g
PeterM Offline
#3 Posted : Friday, 27 April 2007 8:24:31 PM(UTC)
PeterM
Thanks Mick,
I'll give it a go this weekend. I was hoping it was a simple test.
Peter
