#1 Posted : Tuesday, 19 September 2006 9:45:59 AM(UTC)
I finally removed the index finger and started welding the floor on the old bomb today, haven't done oxy for years, and found the nozzle kept popping like a machine gun, have to shut off oxy, light goes out, relight and start again, this was driving me mad.
I have got new gauges that are in N or kp or something metric and being used to psi am not sure what pressure should be running, usually use around 5 psi acetylene/15 oxy, so theoretically around 25/30 and 80 or so oxy should do.
what am I missing?
#2 Posted : Tuesday, 19 September 2006 10:15:28 AM(UTC)
Hi John,
Close enough, 1 PSI = 7 KPA, so 5 PSI should be 35 KPA and 15 PSI should be 105 KPA.
HTH
Cheers...Dave
ozchevy Offline
#3 Posted : Wednesday, 20 September 2006 9:09:31 AM(UTC)
ozchevy
John,
Sounds like the tip needs cleaning?
ozchevy Offline
#4 Posted : Wednesday, 20 September 2006 9:15:15 AM(UTC)
ozchevy
#5 Posted : Thursday, 21 September 2006 11:34:11 AM(UTC)
Thanks dave and ozchevy I was wondering if I did not have the handpiece on enough pressure.
I have saved that welding site for check later thanks.
This page was generated in 0.147 seconds.
