#1 Posted : Friday, 20 April 2007 7:22:04 AM(UTC)
I need a new cab for my 1 tonner.. I want to know are all the cabs from HJ/Q X WB etc interchangeable, and same with the panels??
any help and advice would be appreciated.. I have rust in the pillars
#2 Posted : Friday, 20 April 2007 10:23:03 AM(UTC)
HQ is one on its own due to the dash. The HJ - HZ's have the HJ - HZ dash but, generally, also have the HQ plenum (that doesn't line up with the HJ - HZ bonnet ridges).
WB's have the HZ dash but the HJ - WB Sedan, etc plenum.
For interchangable pane
#3 Posted : Friday, 20 April 2007 4:44:29 PM(UTC)
Other problems are:
HQ cab has no provision for retractable seat belts.
HJ-WB don't have the mounts for HQ accelerator linkages.
HQ and HJ have a different clutch setup to HX-WB so the mount for the top of the rat-trap isn't there on HX-WB cabs. And co
#4 Posted : Saturday, 21 April 2007 9:25:52 PM(UTC)
So what ive gathered is that the HJ and HZ are basically the same shell and everything should line up??
everything else is a little tricky..??
#5 Posted : Sunday, 22 April 2007 1:19:51 AM(UTC)
Pretty well, yes, although you can include HX in that range too.
Anything else will work but will need more work to make it go together properly.
If you have a normal Sedan type front on your tonner, a WB cab will also be fine for you, maybe except
#6 Posted : Sunday, 22 April 2007 1:22:34 AM(UTC)
HX and HZ are basically the same. HJ has a few minor differences if you read my post above, as does WB. There is also a HJ, HX and HZ Ambulance pack cab that has the HJ-WB cowl but these are pretty rare.
________________________________________________
