#1 Posted : Saturday, 21 April 2007 1:55:06 AM(UTC)
has any tried to reco wiper motor ie brushes etc ? ihave and its hard to get it back together cheers
peterwmh Offline
#2 Posted : Wednesday, 25 April 2007 5:42:57 AM(UTC)
peterwmh
Yes they are a pain to get back in as you need to hold the spring loaded brushes back and then get the armature back in place, not easy and the brushes want to slip sideways! I'm not sure how they'd do it, but there must be a way!!
Peter
202 and th
#3 Posted : Wednesday, 25 April 2007 5:45:45 AM(UTC)
I have never put a wiper motor back together...Is there a small hole near the brushes for a piece of wire to go through and hold them back while you assemble the motor?
Cheers...Dave
#4 Posted : Friday, 27 April 2007 1:44:10 AM(UTC)
plus the magnets tend to drag the outer case all over the place when your tryingto get the brass bush to seat in the bottom ihave tried their must be a better way cheers
#5 Posted : Friday, 27 April 2007 2:07:42 AM(UTC)
Try using cotton , loop it around the the brush face ie place it across the brush face the pull both end to the edge of the housing and hold it this will hold the brush in place while you put the housing on. When the housing is almost home look to see i
Edited by user Friday, 27 April 2007 2:10:03 AM(UTC)  | Reason: Not specified
