basketcasebear Offline
#1 Posted : Saturday, 23 September 2006 5:08:20 AM(UTC)
basketcasebear
hey all,,, have done it,,, 308 t 400 into 98 ford transit??? now before you all start saying what idiot would do that to a transit??
whell they have ps, wheels in front of drivers seat, good sized van, drive nicely on road,, and I needed a van like this because of damaged spinal chord..
so I wonder,,, engine is reving about 400 revs too much at 100k.s, 2800, at 80k.s
how much bigger do I make back wheels, so this drops down to about 28>2900 at 100k.s?
I have to get wheels made anyway because there is nothing decent to fit to transit??
your help is already appreciated
ptpro
DOH!!!
#2 Posted : Saturday, 23 September 2006 9:25:11 AM(UTC)
I really couldnt tell you mate!!
If you could convert to Falcon stud pattern you'd have a better chance of getting wheels, but you'd need some 20" wheels to make that happen.
It'd probably be cheaper for you to just get your diff gears changed to a
#3 Posted : Saturday, 23 September 2006 10:12:17 AM(UTC)
Many moons ago, a mate of mine had a couple of transits, both 250/auto combos.
In both of them, he had a Falcon diff centre cut n shut to fit with the Transit axles/wheels/etc. He went for the 3.23 ratio and the diffs were out of XY or XA Falcons or so
#4 Posted : Sunday, 24 September 2006 7:24:04 AM(UTC)
basketcasebear
hey thanks fellas,,,this is what i figured,, if i have to get wheels made, and being virtually einstein!! then 4 costs issue, i thought i need to drop revs by about 10%>15%
3300r@100klms - 10>15% 330>500 = 2800>2900r@100klms? figured get wh
DOH!!!
#5 Posted : Sunday, 24 September 2006 7:47:02 AM(UTC)
Qute is onto something there!! Maybe thats the go as with the older diffs you tend to have your choice of diff gearing...
Keith
#6 Posted : Sunday, 24 September 2006 10:04:56 AM(UTC)
Hi fallingbear,
There is a flaw in your thinking...larger diameter wheels are usually wrapped in lower profile tyres, so you end up with the same overall diameter... have a look here: http://www.oldholden.com....php/Changing_diff_ratio for
#7 Posted : Sunday, 24 September 2006 7:50:31 PM(UTC)
basketcasebear
thanks everyone, will do some more complex mathematcal computationns,
although wheels on transit are quite small, a couple tractor wheels should do it??
hehe
ptpro
DOH!!!
#8 Posted : Monday, 25 September 2006 10:27:47 PM(UTC)
I seem to remember something about the Transit sharing the 5 stud pattern with the F100 & Chevrolet C series.
I could be completely wrong here though.
Another option which is a variation of Daves is to find the diff out of a late 70's Transit
#9 Posted : Tuesday, 26 September 2006 12:00:10 AM(UTC)
basketcasebear
Hey jim 05...I only found out yesterday,,that the vn came out with a t700 without computer bull****,,and thats what i dont want,computer bull****!! i am able to maintain van with normal set up,,myself, i know if plugs need replacing, or timing needs adjus
DOH!!!
#10 Posted : Tuesday, 26 September 2006 12:51:17 AM(UTC)
VP's had the none computer controlled TH700 also. They were also called 4L60 & 4L80 I believe.
They became 4L60E & 4L80E when they went electronic.
CRS does a kit to mount a V6 box behind a V8 block if the V8 box becomes too hard to get.
This page was generated in 0.080 seconds.
