#1 Posted : Tuesday, 26 September 2006 7:27:19 AM(UTC)
Ok this is gonna be hard to explain but I own a 1975' XB the motor I currently have in it is not the original.
Here is my problem, I wanna find out exactly what the motor was (eg. 351 4V, 302 2V etc)
Now I know 1 way is to look up the engine code (EG T, G) on the compliance plates.
But since I dont have the car the motor came out of, that option is not possible.
But I do know the VIN Number of the car the motor came out of.
What I ask is that does anyone know where I can use the VIN Number to look up the car and either find the Engine Code or What Engine it was.
Any Help Would be appreciated.
ENG NO - JG31ST72633K
Thanking anyone who can help in advance...!
Paul351xb Offline
#2 Posted : Tuesday, 26 September 2006 11:15:39 AM(UTC)
Paul351xb
OK without the plate there isnt much to go on unless you try ringing Ford itself. From what i can work out the motor is out of a falcon station wagon, build date is December 1976. So if original the engine will either be a 2V 302 or a 2V 351. Can't hel
Munromad2004 Offline
#3 Posted : Wednesday, 27 September 2006 4:44:01 AM(UTC)
Munromad2004
Do you have the engine number?
That would help a lot.
If it is the original engine from the vehicle that you have the VIN number for, then it's engine number should match that VIN number and as Paul stated will be a 2V 302 or 351.
#4 Posted : Friday, 29 September 2006 5:55:37 AM(UTC)
Well yeah in my post i have given the engine number which would be the same as the car vin number so i am able to work out what car it came from but not if it is a 351 or 302
Paul351xb Offline
#5 Posted : Friday, 29 September 2006 9:04:34 AM(UTC)
Paul351xb
From memory the XC 351s had blue rocker covers and the 302s had orange rocker covers. Sure fire way to tell is to measure the stroke with a piece of wire. 3 inches for a 302, 3.5 inches for a 351.
Edited by user Friday, 29 September 2006 9:10:00 AM(UTC)  | Reason: Not specified
#6 Posted : Saturday, 30 September 2006 12:50:16 AM(UTC)
Unfortunaly it came with chrome covers. how do i do the wire thing, if its not to hard to explain?
#7 Posted : Saturday, 30 September 2006 1:52:34 AM(UTC)
Your motor came out of a December 1976 built Falcon 500 wagon
and its a 351 cleveland 2v
Hope that helps
If I'm going to HELL it will be in an XB COUPE!
#8 Posted : Saturday, 30 September 2006 4:06:16 AM(UTC)
Munromad2004
How did you tell it was a 351 from that info?
Paul351xb Offline
#9 Posted : Saturday, 30 September 2006 8:44:37 AM(UTC)
Paul351xb
yeah, i'm curious too????
Paul351xb Offline
#10 Posted : Saturday, 30 September 2006 8:55:24 AM(UTC)
Paul351xb
XB owner, grab a piece of wire, old coathanger should do and straighten it out. Take a spark plug out. Drop the wire into the hole and hand turn the engine. When the piston is bottomed out measure the distance that the wire rises out when you crank it
#11 Posted : Saturday, 30 September 2006 6:16:01 PM(UTC)
My Uncle used to work for ford and he's got a book with all vin numbers
and option codes that went on that vehicle from the factory from 1976 to 1977.
Paul351xb Offline
#12 Posted : Saturday, 30 September 2006 8:31:12 PM(UTC)
Paul351xb
Mate, that book is like gold, there would be a lot of people that would love to have that sort of infomation on hand.
#13 Posted : Wednesday, 11 October 2006 5:05:47 AM(UTC)
Can anyone tell me what my vin number tells me about my engine?
jg37nc24507k
#14 Posted : Wednesday, 11 October 2006 6:39:31 AM(UTC)
Munromad2004
Its a V8 from a Sep 73 built Fairlane 500.
Edited by user Wednesday, 11 October 2006 7:12:50 AM(UTC)  | Reason: Not specified
#15 Posted : Wednesday, 11 October 2006 7:40:31 PM(UTC)
302c or 351c?
#16 Posted : Thursday, 12 October 2006 5:30:52 AM(UTC)
Munromad2004
There's no way to tell. Sorry.
You'll have to measure the stroke somehow. (piece of wire down the sparkplug hole is one possible way.
3 inch stroke for a 302 and 3.5 inch for a 351.
I have also heard that 302's and 351's had different colour rocker
Edited by user Thursday, 12 October 2006 7:13:56 AM(UTC)  | Reason: Not specified
#17 Posted : Thursday, 12 October 2006 11:58:32 PM(UTC)
My rocker covers are orange which is supposed to mean that i have a 302,
Also i have a c4 and my car does not have a disc-brake rear-end and it has a 2bbl manifold with a 350 holley,
So in all likely-hood my car is a 302 as 351 equipped ZG's apparentl
Paul351xb Offline
#18 Posted : Friday, 13 October 2006 9:27:16 PM(UTC)
Paul351xb
Is the engine in the car original? If so you can tell what type of engine it is by reading the info on the Vin plate. Some ZGs 351s did come out with 2 barrel manifolds and carbs. They should have a nine inch out the back and an FMX box. In all likely
#19 Posted : Friday, 13 October 2006 10:58:24 PM(UTC)
It has a 9" Diff, with Drum rear brakes and it has a C4 for certain, im pretty sure its the original engine, but who knows, someone could have rebuilt it and thrown 351 rods and crank in there.............
Have to measure,
Paul351xb Offline
#20 Posted : Saturday, 14 October 2006 1:07:01 AM(UTC)
Paul351xb
Tony, read what the code is on the plate. Where it says ENG. should either be T, K, or Y. T is 4V 351, K is 2V 351 and Y is 302.
