#1 Posted : Wednesday, 27 September 2006 3:55:57 AM(UTC)
hi guys can some help me i have a 253 im my hz sedan it has a three speed coloum i reacently picked up a 4 speed out of a worked vk 6 (mate had it in shed wrapped in plastic ) i wanna put it in what mods do i have to carry out ayny help would be cool
#2 Posted : Wednesday, 27 September 2006 3:40:41 PM(UTC)
That 4-speed is probably no good to you, unless it's an aussie 4-speed. If it is an M20 aussie box you can rebuild it to suit a 253, but you will need a V8 input shaft and V8 dust cover (cover over the front shaft). If your HZ is a 3-speed column shift, a
#3 Posted : Thursday, 28 September 2006 7:15:44 AM(UTC)
thanks it is a manual 3 speed and what is wrong wit the mc6 i think this might be a mc6 as there are no linkage and cant i just swap the input shafts around
#4 Posted : Thursday, 28 September 2006 7:51:05 PM(UTC)
The MC6 is not a strong box. It was built in the Phillipines I think, and as far as I know there is no bellhousing available to fit it behind a 253. Plus there is no V8 input shaft for you to swap around. You'll have to find a V8 aussie 4-speed. Don't buy
#5 Posted : Friday, 29 September 2006 7:03:22 AM(UTC)
it is in good nick and cheers man u helped a lot and could u give me gregs contact info and i will go from there thanks a agin
#6 Posted : Friday, 29 September 2006 6:10:17 PM(UTC)
Watch the banner ads at the top of this page for Classic Oz Wreck. Just remember that I can't do one until next year for Greg. You'll have to talk to him about what sort of rebuild you want, ranging from new bearings with good secondhand gears up to a rec
This page was generated in 0.132 seconds.
