#1 Posted : Wednesday, 27 September 2006 5:51:16 AM(UTC)
Because trying to tune (What i can tune on this Pr*ck of a thing) is realy starting to P*ss me off!
I know alot of guys terf these things, and im strting to see why.
BUT, before i go blamming the Carb. Does any one have the Adjustment settings for the Two screws (one is an Idle mixture screw im sure) that i can locate?
Next to that, Other then the VK efi(Im just looking for simplisity hear), What Cheap Carb options are there, XE/F fords?
Thanks guys.
#2 Posted : Wednesday, 27 September 2006 8:05:49 AM(UTC)
The 2 screws are easy.
The one closest to the manifold is the idle mixture - tune this for maximum vacuum at idle.
The one higher up (much larger) is the idle bypass tube - winding it in or out affects the idle speed at closed throttle - it's an idl
#3 Posted : Thursday, 28 September 2006 6:09:53 AM(UTC)
Although I never really played around with the Varajet I had on mine, it had a terrible flat spot from brand new (according to my old man). I had it rebuilt and tuned (by Procarb) but still didnt fix the problem. I put a reco'd holley 350 on it and the
This page was generated in 0.283 seconds.
