Hi all wondering if anyone can tell me if I have the origional motor in my GTS. Can you tell me if this is the original motor please,
Model No: HJ8WQ69
Body No: 196278/A
Trim: 1890/60Y
Paint No: 568/15953
Engine: L32
Trans: M20
rraxel: GU4
Chassis No: BHJ61381A
Engine No: HR47008
Build Date: 07/1976
G'day mate what you should have is a 253. One of the other guys will be able to tell you for sure but I think your engine prefix should be a q?
Yeh thanks for that. I know it's a 253 but I want to know if it's that origional motor as previous owners saidthey never changed it.
Hi xbro87.
The HR prefix is for the 253 V8 used in LH/LX Toranas. The number places it around mid '75. It can't be the original motor for an HJ.
Your HJ GTS has a build date of 7/76 ?? Is that the date on the Compliance plate. Does it have ADR27A on |
Post the VIN number (off the skinny plate) and I'll try to check it out for you. As Terry says it's not the right engine number, but I'll see if I can get the original number for you. Takes a while though, and not always recorded. |
Check the block casting date mark just below the head above the oil pump.
The first no is the day. The letter refers to the month ie A = Jan, B = Feb etc. The last character refers to the year.
James
You only have to be in front at the end of the race. |
sorry about that Dr Terry you're right the build date reads 06/76 there was quite a bit of **** on the plate now it's clean I can see it properly. So there is no way this can be origional motor eh.Thats so dissappointing> I was told all it had matchin
Cheers Bryon the skinny plate reads 8069 RL348601J. Any info is much appreciated
Should hear within a week. Check the numbers/letters carefully too. You have at least one incorrect - should be 8Q69 not 8069 |
xbo87. Here is the original details off your car:
Engine number was QR750255. Car was a standard HJ GTS with no mechanical options. Build date was 07/06/76. Sales date was 7/76 through Motors Limited in Hobart.
thanks heaps for the info Byron. I was told on the weekend about restamping of engine numbers provided the number isn't in use.Is this legal and who would do it. cheers xbro87
