YetAnotherForum.NET Help
#1 Posted : Tuesday, 3 October 2006 7:41:49 AM(UTC)
Hey there
I'm about to embark on a pickup project. Its an old chev - but does have the holden badges on the side!! (it was assembled and sold by holden). I've always been keen on a modern driveline for the old pickup so was considering using a recent model commodore as a donor vehicle, but I run straight gas on my HJ and have become a fan of gas research, so have started to lean towards straight gas as possibly a better option for the project, as I would like it to be a daily driver, and this would save me a bit of hassle in getting it all set up and running I guess.
So if I go straight gas, is there any benefit to using say a VN 5L, or would I be just as well off getting a cheaper older model with a 308? If I was going an older model, I probably wouldn't be adverse to a 253 either.
Decisions decisions....
Your thoughts and recommendations would be much appreciated!
Richo
#2 Posted : Tuesday, 3 October 2006 5:14:46 PM(UTC)
Richo, Twin gas research on a old holden 355 stroker. Way to go. The 253 might be a bit small considering the weight of the truck. Cheers, Glenn
#3 Posted : Tuesday, 3 October 2006 6:40:03 PM(UTC)
I'd use a Chev, just to be 'true' to the truck, like a 283. But don't ignore the Holden V6 or V8. You can buy complete cars with 4-speed auto boxes for less than $1500 as a wreck for a V8 or less than $1000 for a good V6. With something like a truck you c
#4 Posted : Tuesday, 3 October 2006 11:15:50 PM(UTC)
I'm basically starting with scratch with the pickup - I've basically got a rolling shell - its a blank canvas! Buying a wreck is an attractive option for that reason so I can hopefully use a stack of other parts as well, which as you said Byron, hopefully
#5 Posted : Wednesday, 4 October 2006 2:58:09 AM(UTC)
That's why the EFI 304 and TH700 would be suitable. You may even be able to use the VN/VP diff which will be a 3.08:1 ratio.
peter_flane Offline
#6 Posted : Wednesday, 4 October 2006 7:40:04 AM(UTC)
peter_flane
It's not too hard to get the ratio changed to something like 3.45 That's what I did with mine.
#7 Posted : Wednesday, 4 October 2006 10:50:22 AM(UTC)
What about a Crate 350? I think the main supplier is called Suburban Imports.
Cheers...Dave
#8 Posted : Thursday, 5 October 2006 3:17:58 AM(UTC)
I have drooled over crate engines, but when I'm starting with a bare rolling shell - the cost and then having to track down all the other accessories scares me a bit...!
Sounds like the 304 might be the easier option
Vintage Caravans Offline
#9 Posted : Thursday, 5 October 2006 5:12:35 AM(UTC)
Vintage Caravans
in this vein, how much more difficult is it to set up the Efi for the 304 over the very simple carby version? exactly what needs to be done, I think there needs to be a fuel return line, the change of filler neck, swirl pot, and then some way of adapting
1962 EK Wagon - Chev SBC & T700, 1962 EK Sedan - Chev SBC & T700,EK Ute - V6 Buick & 5 speed = LOOKING FOR A 1962 EK VAN
#10 Posted : Thursday, 5 October 2006 5:57:34 AM(UTC)
Read what Brett has done on this site:
http://members.ozemail.com.au/~brettsueferguson/index.htm
He has made it even harder on himself by using a V6 (V8 is much easier into a model that has a Holden V8 as an option) and connecting up the column shift,
Edited by user Thursday, 5 October 2006 8:25:04 AM(UTC)  | Reason: Not specified
#11 Posted : Thursday, 5 October 2006 7:39:34 AM(UTC)
Byron, is that link working? i'm getting an error page?
i'd rather hated for who i am than loved for who i am not.
#12 Posted : Thursday, 5 October 2006 7:07:37 PM(UTC)
Just worked now. I've had it not work at times too.
#13 Posted : Thursday, 5 October 2006 11:26:42 PM(UTC)
Hi Byron,
I had to remove the full stop at the end of the link in your post for it to work.
Cheers...Dave
This page was generated in 0.134 seconds.
