#1 Posted : Friday, 6 October 2006 12:02:16 AM(UTC)
I have a mild 308 in my HG running a Holley 600 Vac. Sec. The thing starts very easily and makes good power but constantly runs rich, fummey and plug colour. When I jet it down say, 63's it develops a lean flat spot which isn,t there with the 65's.I just read here where the 600 vac. sec. is regarded as crap! Is my carby the problem being too basic for the Donk? 308 pacemakers,mod. HQ heads,roller rockers, Eddlebrock manifold,Pro-Comp Elect. Dizzy all sitting on a fresh 308 through a 3000 stall.
jabba Offline
#2 Posted : Friday, 6 October 2006 3:30:04 PM(UTC)
jabba
Basically, no. But it is a bit of a b*tch to set up (because there are so many adjustments).
I ran one on a 400SBC with tri-y's, truck cam, etc and it did take a bit of fiddling (and there were a couple of gotchas to getcha).
If it is constantly ri
#3 Posted : Saturday, 7 October 2006 9:17:52 AM(UTC)
jabba is right they can be bitchs to set up. To set it up right you need to know how much vacuum you have at idle to set the power valve.Like jabba said if the vac is too low the power valve will stay open dumping fuel in too the engine.When you adjust t
Sandman Offline
#4 Posted : Saturday, 7 October 2006 6:54:55 PM(UTC)
Sandman
If it's a 600 with a metering plate, not a block in the secondary's they are the cheapest 4bbl holley made. Ya get what you pay for!!
Altho in saying that, they should still run reasonably.
Check it has the right power valve. From memory a std 600 PV i
sandman77 Offline
#5 Posted : Friday, 13 October 2006 9:07:33 AM(UTC)
sandman77
Hey Kent ,
Mate i had the same problem when i had a brand new 600 fitted , tried jetting up and down , like you said was starting easy & good take off but flat spots & was running very ritch . My motor is brand new 308 (rolla rockers ,Edelbrock to
