#1 Posted : Wednesday, 25 April 2007 9:36:11 PM(UTC)
Greetings
I've owned a HJ Sandman van since new (purchased from Wyong Motors, May 1976). I still drive the vehicle once a week. The van is a Brisbane build, XX7, trim - slate black, but with 19V in the trim field (obviously must be a mis-stamping!). The vehicles tyre placard reads 9941015. This is the original tyre placard for this vehicle.
I've recently aquired an extremely rusty HJ Holden Panel Van which I believe is also an original Sandman. The vehicle is complete and original with all the correct trim and fittings. It is an Adelaide build, hence no XX7, however the tyre placard appears to be original and also matches the numbers above. What does all this mean???
hx-sandman Offline
#2 Posted : Wednesday, 25 April 2007 10:40:22 PM(UTC)
hx-sandman
The 19V was the HJ trim code for black. HX was 18V from memory. Byron will be able to tell you more or you can check
www.monaroparts.com
and
www.sandmanowners.com
Should have all the info you need.
Nick
HZute-efi-VS5L Offline
#3 Posted : Thursday, 26 April 2007 3:04:39 AM(UTC)
HZute-efi-VS5L
hey mick,
i would love a picie of the tyre placard. hj sandy placard acording to all hj parts books i have seen is either
6cyl Panel Van, Ute 9930172
V8 Panel Van, Ute 9930173
but saying this i think byron on his site even stats something about th
www.stickthisdecals.com.au
