#1 Posted : Friday, 13 October 2006 12:19:54 AM(UTC)
Hi I am new to this site and I would like to know if anyone can help me. I have a xf s pac series 2 1985 unleaded. It is running crap. It runs ok when you are driving but will not idle....any suggestions please
XB351 Offline
#2 Posted : Friday, 13 October 2006 1:57:18 AM(UTC)
XB351
probably a airflow meter failing. It was a common problem on XF EFI's.
#3 Posted : Friday, 13 October 2006 3:16:14 AM(UTC)
it seems it was a carby problem...btw it doesnt have efi is carby
#4 Posted : Friday, 13 October 2006 3:58:17 AM(UTC)
the carb has an idle switch on the side of the carb,it has a wire going to it,without them or if they fag out it will idle like crap/not at all until the revs rise.unleaded wasnt until 86
sportycorty Offline
#5 Posted : Tuesday, 14 November 2006 4:12:04 AM(UTC)
sportycorty
where does the idle switch wire go to?
sly376 Offline
#6 Posted : Tuesday, 12 December 2006 9:37:30 AM(UTC)
sly376
Yeah sounds like your idle solinoid is not working.
#7 Posted : Tuesday, 12 December 2006 6:08:44 PM(UTC)
the idle switch is on twin barrel carbs from the xe/xf motors its on the pass side of the carb cant miss it its got a wire and a plug on it.
#8 Posted : Tuesday, 12 December 2006 11:05:33 PM(UTC)
I have an XF carb at home from my Dads old series 2 XF & the idle solenoid is vacuum operated so it does not have the wires. Maybe yours is a vacuum operated one & this is why you can't find any wires except the one to the choke.
This page was generated in 0.094 seconds.
