#1 Posted : Tuesday, 17 October 2006 1:36:48 AM(UTC)
I have a 71 HQ coupe and it's receiving a 350 010, turbo 350 and 9 inch. I am wondering what to do with the tailshaft. Will there be one floating around somewhere that will fit? Am i best off just paying for a custom one?
Brett.
pwrslave Offline
#2 Posted : Tuesday, 17 October 2006 2:47:17 AM(UTC)
pwrslave
You may be lucky enough to find one in the trading post or similar, but for what you would pay for a s/hand shaft($150-200) you could get a brand new one built for around $350-$400. Then you,ve got the piece of mind of having everything brand new and bala
#3 Posted : Tuesday, 17 October 2006 2:58:47 AM(UTC)
If you want to modify one, look around for a HQ-WB 1-tonner shaft and get it shortened. The tonner yoke will fit into the TH350 (or at least 99% of them will - see note below) and it uses bigger unis on both ends than a normal Holden V8 tailshaft. The big
Edited by user Tuesday, 17 October 2006 3:05:17 AM(UTC)  | Reason: Not specified
#4 Posted : Tuesday, 17 October 2006 3:11:15 AM(UTC)
Thanks for the help. The 9 inch has the yoke to suit holden uni's... so the tonner tailshaft is looking the goods. Is this the same as a ute tailshaft too?
DaMiEn Offline
#5 Posted : Tuesday, 17 October 2006 4:28:57 AM(UTC)
DaMiEn
no ute panno have a shorter tail shaft (6 inches shorter i think)a lot less stocky a lot of the tail shafts i have seen are only skinny and the on my tonner is pretty big in comparsion have u tried greg at classic oz wreck (49594546) he has a pile of them
classic oz wreck Offline
#6 Posted : Tuesday, 17 October 2006 5:36:41 AM(UTC)
classic oz wreck
ive got heaps of tonner tailshafts if u need one..mention this forum...cheers greg
www.classicozwreck.com.au
#7 Posted : Tuesday, 17 October 2006 6:24:59 AM(UTC)
What state are you in greg? Im in victoria.
peter_flane Offline
#8 Posted : Tuesday, 17 October 2006 7:02:15 AM(UTC)
peter_flane
I would suggest new 3" tailshaft.
#9 Posted : Tuesday, 17 October 2006 8:46:02 AM(UTC)
#10 Posted : Wednesday, 18 October 2006 6:02:49 AM(UTC)
classic oz wreck
brett,if you want one to cut down $120 delivered..do your home work first...cheers greg
