tommo Offline
#1 Posted : Tuesday, 17 October 2006 6:13:50 AM(UTC)
tommo
Hi all
Q: Will a fuel tank out of a Kingswood fit in my HK Brougham or do I have to get one out of a Prem. And is the front screen out of a prem the same
Thanks for your response in advance
Regards Tommo
#2 Posted : Tuesday, 17 October 2006 7:44:40 AM(UTC)
All HK tanks are the same. Some HTG tanks have a second breather.
Make sure its a HK tank and you should be right.
#3 Posted : Tuesday, 17 October 2006 8:43:00 AM(UTC)
Was thanked: 608 time(s) in 575 post(s)
All HK broughams should have a banjo tank. Just avoid a tank out of a 10-bolt or 12-bolt HK.
tommo Offline
#4 Posted : Tuesday, 17 October 2006 5:23:54 PM(UTC)
tommo
MY BROUGHAM HAS A 10 BOLT IN IT DOES THAT MAKE IT DIFFERENT
#5 Posted : Tuesday, 17 October 2006 11:56:22 PM(UTC)
From the factory, all Salisbury equipped HK-HG's had a hump in the floor above the diff and a corresponding hump in the fuel tank. According to Ben Stewart the hump is not necessary to clear a 10-bolt, but was necessary to clear a 12-bolt. So you should b
tommo Offline
#6 Posted : Saturday, 21 October 2006 11:51:10 PM(UTC)
tommo
Thank for your help
Guest (5)
