Hi all Q: Will a fuel tank out of a Kingswood fit in my HK Brougham or do I have to get one out of a Prem. And is the front screen out of a prem the same Thanks for your response in advance Regards Tommo
All HK tanks are the same. Some HTG tanks have a second breather.
Make sure its a HK tank and you should be right.
All HK broughams should have a banjo tank. Just avoid a tank out of a 10-bolt or 12-bolt HK. |
MY BROUGHAM HAS A 10 BOLT IN IT DOES THAT MAKE IT DIFFERENT
From the factory, all Salisbury equipped HK-HG's had a hump in the floor above the diff and a corresponding hump in the fuel tank. According to Ben Stewart the hump is not necessary to clear a 10-bolt, but was necessary to clear a 12-bolt. So you should b |
