Simmo Offline
#1 Posted : Sunday, 22 October 2006 3:07:45 AM(UTC)
Simmo
I'm in the process off ripping off mags and reverting to steel rims with original hubcaps.
Had the wheels balanced but weights on the outside face of the rim prevent the hubcap from fitting. What's the solution?
Munromad2004 Offline
#2 Posted : Sunday, 22 October 2006 3:24:33 AM(UTC)
Munromad2004
You may be able to get them rebalanced and the weights fitted on the inside.
The do this quite often on flashy mag wheels for cosmetic reasons.
They generally use flat stick on weights when they do this too.
That's exactly how my alloy wheels on
edelbrock1 Offline
#3 Posted : Sunday, 22 October 2006 6:10:31 PM(UTC)
edelbrock1
Ask for a 'static' balance, and explain that you dont want the weights on the outside. I have never had any problems doing this. Ihave asked about the flat mag wheel weights, and they wont put them on steel wheels. Go with the static balance and see wh
#4 Posted : Monday, 23 October 2006 5:23:34 AM(UTC)
Im in adelaide and need a resto on original HG monaro hub caps. N E one got idea
#5 Posted : Monday, 23 October 2006 6:05:52 AM(UTC)
Munromad2004
I got the following info from another forum a while ago and saved it for future reference as I also have a set that need restoring eventually.
If you do contact this mob, I would appreciate it if you could let me know how you got on.
"You should try
