80737k Offline
#1 Posted : Monday, 23 October 2006 10:45:37 AM(UTC)
80737k
A mate bought an XE with an M+W rebuilt 351 and shift kitted C10 which we just pulled out. It's going into his F350 that currently runs a 250 x-flow and and original f350 4 speed box. Pete was told that the C10 would be fine as they are a h/d auto. The problem is that i'm pretty sure that the auto is a C4 as it looks like my C4, which i believe are difrent looking to the C10. If it is a C4, Will it be ok in the truck?
Ooroo
Fossil fuels are YUMMY !
#2 Posted : Monday, 23 October 2006 5:49:57 PM(UTC)
im pretty sure the c4 has the dipstick tube going into the front caseing and the c10 has the dipstick tube going into the auto oil pan?both will be fine.
80737k Offline
#3 Posted : Tuesday, 24 October 2006 12:24:20 AM(UTC)
80737k
Well we might be ok then as the dipstick on this goes into the pan, thanks mate.
Ooroo
#4 Posted : Tuesday, 24 October 2006 5:42:51 AM(UTC)
just looking at this again,what motor is he planing on using infront of the auto?
#5 Posted : Tuesday, 24 October 2006 6:43:20 AM(UTC)
He's using a 351.
#6 Posted : Tuesday, 24 October 2006 6:10:35 PM(UTC)
ok should have no troubles,will need f100 engine mounts,im guessing a tail shaft/maybe a gearbox mount?/excel cable/and maybe a speedo cable?not real sure as i havnt done it but this sort of stuff usually neds to be changed when doing a v8 conversion.
#7 Posted : Wednesday, 25 October 2006 7:15:03 AM(UTC)
c4 and c10 is the same, c10 is a made up name. dipstick in the pans means it is from a cleveland engine, dipstick in the case means it is from windsor engine.
This page was generated in 0.091 seconds.
