eskimo_joe777 Offline
#1 Posted : Wednesday, 25 October 2006 3:50:55 AM(UTC)
eskimo_joe777
Is there much work in putting a bumper off a HZ wagon onto my HJ Van?
i have it ready to go on but just wondering if there is any easy way or not? I was just going to make up a new bracket to bolt it on..
Thanks Justin
#2 Posted : Wednesday, 25 October 2006 5:16:12 AM(UTC)
[Just think about opening the tail gate.I think that the back panels are all the same i allso think you should be able to mod the irons as well that is if my memory is still working it as been i few years since i last worked on them
regards Tommo]
peter_flane Offline
#3 Posted : Wednesday, 25 October 2006 8:52:31 AM(UTC)
peter_flane
Just check the width. If you put a wagon bumper on a ute the ends stick out a bit, enough to put your hand between the bumper and the body. They can be shortened in the middle and rechromed no problem.
#4 Posted : Wednesday, 25 October 2006 5:25:48 PM(UTC)
They fit, but you have to make up brackets. You cant drop the tailgate down all the way with a full bar, and your towbar will probably be useless.
#5 Posted : Thursday, 26 October 2006 12:41:15 AM(UTC)
i found with fitting one.it fitted but it still touched at the ends. only just, i used a hammer and doly on the body to make it look right. when its all set up keep your eyes out for a HQ wagon rear bar.They are the same shape as the bumperettes but full
Intoit Offline
#6 Posted : Thursday, 26 October 2006 1:32:24 AM(UTC)
Intoit
Make up some brackets like these and drill new holes in the back of the van .
Yes the tailgate will drop dow
--------------------Go Hard Or Go Home
