#1 Posted : Wednesday, 25 October 2006 6:25:16 AM(UTC)
Hi, monotorque gaskets on a red 308, do the beads of blue silicone go to the top (head side) and is this the same on both sides.I had the motor reconditioned 3000km ago, not sure now witch way I put them. The driver side head is leaking from the front now. I have checked all bolts and they are still ok. I have been using nulon coolent and have just read on ACL's website to use distiled water not tap water, nulon said the same, would this cause a leak after 3000ks. and help would be great.
Craig
#2 Posted : Wednesday, 25 October 2006 6:27:54 AM(UTC)
The end should have read (any help would be great)
Cheers Craig
#3 Posted: : Wednesday, 25 October 2006 8:44:40 AM(UTC)
did you retorque the heads at 1000 kms
#4 Posted : Wednesday, 25 October 2006 11:40:51 PM(UTC)
No, ACL said that monotorque head gaskets on holden v8's dont need to be retentioned.
Rimmo Offline
#5 Posted : Friday, 27 October 2006 7:30:23 AM(UTC)
Rimmo
Did you use sealant on the head bolts, some of them go into water. Thats why you don't retorque. The sealant dries hard.
#6 Posted : Friday, 27 October 2006 8:00:53 AM(UTC)
Type of water would have no effect on leaks. Have a look in history there was a big discussion on leaks a while ago.
