#1 Posted : Sunday, 29 October 2006 1:53:50 AM(UTC)
Howdy, Thanks to all for their advice so far. I've been searching old threads to answer most questions, but thought I'd put this one out there...
Was reading that on a red 186 a 350 Holley (while better than a stromie) won't be as efficient as a small 4 barrel. Is a 465 too big - does it need to be a 390?
[I have a 465 but it needs rebuilding - should still be cheaper (?) than a new 390].
If the 465 is ok, what jet size / squirters / pump spring / & power valve should be fitted?
It's a standard 186 that will have extractors & electronic ignition. Will put a cam & some head work on another motor at a later date (haven't decided 186 or 202 yet - I'll have to see what comes up at the righ price), but this is just to get me mobile, but also the parts that I can strap onto the other motor when it's completed, so save buying even more stuff. Thanks again dudes!
The Beige Hornet.
#2 Posted : Sunday, 29 October 2006 1:55:04 AM(UTC)
Sorry, also forgot to ask does anyone know about Edelbrock carbs. Would there be a suitable one...? (they're just so SHINEY!)
The Beige Hornet.
#3 Posted : Sunday, 29 October 2006 2:20:24 AM(UTC)
The 390 suits a 186 better than a 465 but the 465 is still a GREAT carb for the larger Holden 6's.
I can't remember the jets, etc that I ran in mine now :-(
I had one on a worked 186 for years. It went really well and was quite economical if I kept
This page was generated in 0.138 seconds.
