tanart Offline
#1 Posted : Thursday, 2 November 2006 11:06:38 PM(UTC)
tanart
Are the HK disk brake/calipers etc the same setup at the HT and HG? i'm planning of putting my HK GTS back to original, a i have access to HT-HG front end. Currently i have HQ disks and calipers.
#2 Posted : Thursday, 2 November 2006 11:22:12 PM(UTC)
HK and HT are the same, except for manual HT 1837. HG are all the same as the HT 1837. Difference is the thickness of the discs. Have a look at the RDA or DBA website. Regardless of the text on the sites, the thicker disc is the HG one. IIRC the calipers
tanart Offline
#3 Posted : Friday, 3 November 2006 11:40:24 PM(UTC)
tanart
Does this mean the HK GTS 327 disk calipers are the same as HT-HG?
#4 Posted : Friday, 3 November 2006 11:49:40 PM(UTC)
Hi tanart.
The calipers are not exactly the same , but can be made to be the same.
To elaborate on what Byron has said the HK disc rotors are 1/2" thick. All HT rotors are also 1/2" thick except for the GTS 350 (81837) which have 5/8" thick rotors.
