GMH1975 Offline
#1 Posted : Friday, 3 November 2006 1:43:02 AM(UTC)
GMH1975
Hi guys i have just purchased a 1928 chev that i will be turning into a hotrod.
I am thinking of using a HK-HG front and want to upgrade to VN-VP commodore brakes as the car will be running the commodore running gear.
I had a look at the hoppers stoppers website and it states that the front bearings are the same from about EK all the way up to VP so i am assuming i can put VP discs straight onto the HK-HG stubs with out any modification.
Am i correct in thinking this ?
I also want to know if anyone has used the commodore calipers on a HK-HG front end and if so how hard is it to do?
Ant ideas???????
Not the BLOODY Kingswood
#2 Posted : Friday, 3 November 2006 2:04:12 AM(UTC)
Hi GMH175.
Yes, the front wheel bearings stayed the same from mid-FE to VP Commodore, so the disc rotors will fit the stub axle. It isn't that easy though, the caliper mount offset & bolt pattern are nowhere near close, so it's not a bolt-on job.
If
GMH1975 Offline
#3 Posted : Friday, 3 November 2006 2:12:32 AM(UTC)
GMH1975
Thanks for the info Dr Terry.
If i use the hx-wb calipers will they work in harmony with the vp master cylinder and rear brakes?
Your option is preferd over the bigbrake upgrade only thing is i would have to get the studpatern on the hx discs changed to
Edited by user Friday, 3 November 2006 2:14:48 AM(UTC)  | Reason: Not specified
#4 Posted : Friday, 3 November 2006 7:02:54 AM(UTC)
Was thanked: 609 time(s) in 576 post(s)
If it won't you could use a WB Statesman master cylinder.
#5 Posted : Friday, 3 November 2006 6:48:43 PM(UTC)
Hi GMH1975.
The choice of booster & master cyl depends on pedal ratio etc. The HX-WB caliper is very similar to the Commodore anyway, so either m/cyl will do the job.. The HQ to WB master cylinders are 1" bore & most Commodores are 15/16" with the 1" s
JYJ003 Offline
#6 Posted : Saturday, 4 November 2006 12:08:09 AM(UTC)
JYJ003
On my HK, I have used Volvo 740 turbo vented discs, which are the same stud pattern as hk, and early Corvette 4 spot calipers. A billet adaptor was machined up to hold the calipers. The rear cylinders were changed to a larger dia from the standard HK. The
GMH1975 Offline
#7 Posted : Saturday, 4 November 2006 2:34:05 AM(UTC)
GMH1975
The booster a m/cyl will be mounted under the car as a 28 chev dont have much room on the firewall so a custom brakepedal will be made.
I will be using the commodore diff aswell so i want the commodore stud patern up front.
I intend on using as much as
