#1 Posted : Saturday, 4 November 2006 4:03:56 AM(UTC)
Just about to commence converting my standard HVAC system in my VR ute to climate control and wondering if anyone knows if the evaporator temp sensor can be mounted with out complete removal of the HVAC unit - has anyone done this????
#2 Posted : Saturday, 4 November 2006 5:43:22 PM(UTC)
Ideally you have to reove the HVAC box, however....
I used the donor box to work out where to drill a hole in the housing, beside the recirc/fresh flap, above the core - there is a small section between 4 webs.
I then fed a wire up into there, aiming
#3 Posted : Saturday, 4 November 2006 9:33:56 PM(UTC)
Cheers Mick, thanks for the help
I've got a complete donor HVAC box to go of with metal braket for the fan amp and just tried drilling a hole in corner of the the web on you mentioned just next to/above the evaporator and looks as if it will work prett
#4 Posted : Saturday, 4 November 2006 10:08:39 PM(UTC)
The system works fine in the wagon - keeping the temp as accurate as my VS2 Calais.
#5 Posted : Sunday, 19 November 2006 6:04:51 AM(UTC)
IT WORKS :D
Thanks for the help Mick
#6 Posted : Sunday, 19 November 2006 11:31:02 AM(UTC)
Well done Stirlo! :-)
Cheers...Dave
