#1 Posted : Monday, 13 November 2006 6:40:15 AM(UTC)
I cant get the speedo in my xb coupe to work. I have replaced the speedo cable, i also tried a new speedo gauge and it still dosnt work at all. I was wondering if any 1 can help me out nd let me know wat could b the cause of it not working. It is a 351 with a c4. Could the problem b in the gearbox where the speedo cable plugs into??
Munromad2004 Offline
#2 Posted : Monday, 13 November 2006 7:09:50 AM(UTC)
Munromad2004
Mate, there's not many options left as you've eliminted everything else.
I would suggest you try and disconnect the cable from the speedo end and go for a drive and look to see if the cable is turning.
It is possible that the gear inside the transmi
#3 Posted : Monday, 13 November 2006 7:38:11 AM(UTC)
Are you running the right speedo drive at the end of the cable for the C4
#4 Posted : Monday, 13 November 2006 7:57:11 AM(UTC)
yer cheers mate. It is a rather annoying problem.
#5 Posted : Monday, 13 November 2006 7:59:42 AM(UTC)
yer im prety sure. i bought a xb v8 auto speedo cable from ford muscle parts. they only sell them as auto or manual cables so i persume it is the correct cable
Paul351xb Offline
#6 Posted : Tuesday, 14 November 2006 3:02:18 AM(UTC)
Paul351xb
are you sure you have the cable connected into the speedo properly? they are a bit of a bugger to fit sometimes. If not any of the things listed above it may very well be the drive gear inside the C4 like you think.
#7 Posted : Tuesday, 14 November 2006 7:46:34 AM(UTC)
yeah cheers 4 all of the help. the problem must b in the drive gear because the inside of the cable dosnt even spin wen the car is driving. wat a pain in the arse of a problem
This page was generated in 0.095 seconds.
