dose any one know if a larger intake manifold will improve power on lpg or is it a wast of time puting one on (being a dryer fuel would it burn better or slower after. it is on a 308 and sitting on a rodchester out the bonnet allready.
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
Gar Research recommend a single plenum manifold eg Edelbrock Torker, as LPG as it is a gas takes up more volume. But others will tell you that a dual plane is better. In any case if it's a pollution red motor manifold you are better off with something els |
