RobertM Offline
#1 Posted : Tuesday, 14 November 2006 11:54:17 PM(UTC)
RobertM
Excuse the long winded question sorry>>>Anyone with a clevo, can you tell me where the temp sender is situated.Mine is just to the left(looking from the front) and below the thermostat housing.It sits horizontal facing to the front and is screwed direct into the block. Is this correct possie??. Reason for question is i am trying to figure out why temp reads high all the time( gauge goes to 100 in 3 minutes altho thermostat is not open as radiator is cold to touch as are rocker covers.,This positon puts it just below the thermostat bypass the way i see itand maybe it is reading wrong..Should the sensor be engine side of thermostat or radiator side (i.e in the thermostat housing) There are two spare outlets on thermo housing where it could potentially go.. Also i have no heaters so i have 2 plugged outlets on waterpump and one just behind waterpump coming off block and was thinking maybe they need to loop or something/somehow.If anyone has a link or a pic showing the front of a clevo in enuff detail to see hoses etc that would be ace,Thanks Guys
Paul351xb Offline
#2 Posted : Wednesday, 15 November 2006 2:07:29 AM(UTC)
Paul351xb
Robert, my temp sender unit is in the same place as yours. Silly question, what is the motor in and what sort of temp gauge are you running? stock? GS/GT? aftermarket? Maybe you have the wrong sender unit and it's giving false readings? There is a p
RobertM Offline
#3 Posted : Wednesday, 15 November 2006 8:08:33 PM(UTC)
RobertM
Paul, Engine is in 67 mustang. Sender unit is out of a windsor i took out of it and is only 12 months old,The original dash gauge goes str8 to hot also but i have fitted a VDO electric gauge to keep a better eye on it.Repco think its compatable but i,m no
RobertM Offline
#4 Posted : Thursday, 16 November 2006 5:11:58 AM(UTC)
RobertM
Update, Had to do a school formal today, temp went off the gauge and stayed there for 30 minutes until i got home. Looking under hood i noticed the radiator hoses were visually swollen with pressure,New radiator cap is 13 lb but surely theres more pressu
Paul351xb Offline
#5 Posted : Thursday, 16 November 2006 5:33:34 AM(UTC)
Paul351xb
Don't know about the chemical test, but i've heard about the head gasket issue. It's actually a common stuff up. Maybe take the car to a radiator shop. They can stick a gauge on your radiator, check the pressure and flow. It's looking more like a bloc
#6 Posted : Thursday, 16 November 2006 1:09:12 PM(UTC)
Robert, will the temp gauge move up with the Ignition left on (but motor not running) for 3>5 mins?
Ifso check for a bad earth
Cheers Tony
