#1 Posted : Saturday, 5 May 2007 7:41:54 AM(UTC)
i have a 96 el fairmont thet has had front end work done has only 190 000 on clock but will not start have checked fuses and relays has spark any info well be great
#2 Posted : Saturday, 5 May 2007 8:12:09 AM(UTC)
A pure guess here, Daniel...When you turn the key on, can you hear the fuel pump kick in for a couple of seconds? If not, maybe your tachometric relay has gone cactus or you have a loose/dirty connection in your wiring somewhere...
Also worth checking
Edited by user Saturday, 5 May 2007 8:13:16 AM(UTC)  | Reason: Not specified
XB351 Offline
#3 Posted : Saturday, 5 May 2007 9:18:03 PM(UTC)
XB351
coil, inhibitor switch, dead starter, in gear :) and as Qute says.
#4 Posted : Saturday, 19 May 2007 3:11:00 AM(UTC)
If they disconnected the battery - maybe they forget to refit the fuel pump relay earth wire to the battery. It is a single loose wire that can be easily overlooked
#5 Posted : Saturday, 19 May 2007 5:41:40 AM(UTC)
problem fixed thanks for your help it was finaly tracked down to be a that the injectors were not firing (thanks qute for that thought) and cause the injectors were not firing it caused the fuel pump to over work and die
