JBM Offline
#1 Posted : Friday, 17 November 2006 8:54:00 AM(UTC)
JBM
I have a VH 253 that is a bit floaty at 100 km/h on country highways.
What can I do to make the front end a bit firmer without lowering the car?
Are my shocks stuffed?
James
#2 Posted : Friday, 17 November 2006 10:16:53 PM(UTC)
Hi James,
New Strut inserts (front shocks) should definitely help.
You should also be able to get heavy duty, standard height front springs if you want it firmer still.
Cheers...Dave
JBM Offline
#3 Posted : Sunday, 19 November 2006 12:56:51 AM(UTC)
JBM
Ive been told tht theyre pretty simple to change so will give it a go. Thanks.
James
#4 Posted : Sunday, 19 November 2006 2:17:06 AM(UTC)
The rears are easy. The fronts need to be done by someone that knows what they are doing.There is a lot of spring pressure behind that nut on top of the strut.
#5 Posted : Sunday, 19 November 2006 11:38:01 AM(UTC)
If you get the strut inserts (rather than rebuilding the struts), IMHO, they are not THAT hard to change over. You do, however, NEED a pair of spring compressors.
Cheers...Dave
JBM Offline
#6 Posted : Sunday, 19 November 2006 8:03:59 PM(UTC)
JBM
I got out the manual last night and it said the strut assembly will come out with the spring but to change the insert the spring needs to be compressed.
Will go to SuperCheap to check prices today on the compressors and gas inserts.
Will also go to
