#1 Posted : Saturday, 18 November 2006 4:33:14 AM(UTC)
I have a 253 in an LX TORANA, I have rebuilt this motor a few times now, its fairly stock with 40thou os bore a mild cam and standard crank and heads, but with new valves & springs I have replaced the cam each rebuild.
The Problem i have had, is after a month or so after each rebuild , i start to get Backfire through the carby, at around 2500 - 3000 rpm
as soon as this happens i chec the cam, and usually the cam lugs have worn a lot, not all of them, just 2 or 3 and never the same lugs.
i getting fed up !!!!!
Mr Void Offline
#2 Posted : Saturday, 18 November 2006 6:00:03 AM(UTC)
Mr Void
How do you run in your cams?
Do you uses new lifters each time?
Do you use any additives for cam run in?
___________________
Why are you reading this, you should be looking up there^^
Joetech Tonner - coming soon!
___________________
#3 Posted : Sunday, 19 November 2006 12:21:52 AM(UTC)
No , Not really., just take it easy for the first 100ks or so.
i HAVE REPLACED THE LIFTERS ONCE, AND NO HAVN'T USED ANY ADDITIVES
i HAVE :
CECKS SPRING TENSIONS
CHECKED VALVE DIMENSIONS AND SETS
CHECKED PUSHROD LENGTHS AND STRAIGHTNESS
CHECK CONDIT
#4 Posted : Sunday, 19 November 2006 11:41:24 AM(UTC)
You should ALWAYS put new lifters in with a new cam. You should also ALWAYS use a running in lube (also known as cam honey) on your cam and run the motor at a fast idle for about 20 mins when you first start it up.
There are some variations in opinions
Mr Void Offline
#5 Posted : Monday, 20 November 2006 5:50:49 AM(UTC)
Mr Void
Like Qute basically said - failing to run the cam in (in some shape or form) is a major cause for lobe sheering/wearing.
___________________
___________________
