#1 Posted : Monday, 7 May 2007 1:02:49 AM(UTC)
Howdy,
Apart from the 2 carbs, did X2 motors have any other goodies in the head or cam department? Were the blocks differently numbered? I have a HR 186 & have been thinking about building it as an X2.
The Beige Hornet.
#2 Posted : Monday, 7 May 2007 3:31:13 AM(UTC)
Hi Beige.
Yes, there are differences with the cam, head, bearings, manifolds and dissy curve.
A real HR 186 X2 motor will have an engine number of somewhere between 186K1001 to 186K162700.
Dr Terry.
Siggs Offline
#3 Posted : Monday, 7 May 2007 6:25:44 AM(UTC)
Siggs
Dr Terry,
Didn't the X2 have a steel crank as well????
Siggs
#4 Posted : Monday, 7 May 2007 6:51:24 AM(UTC)
Hi Siggs.
Yes, the X2 motor does get a steel crank, but Beige was asking about the differences between a standard 186 & a 186 X2. All 149, 179, 161 & 186 up to April 1967 also have steel cranks and the production of the X2 ceased around the same time.
#5 Posted : Tuesday, 8 May 2007 5:25:01 AM(UTC)
So realistically there's probably no point in building it to X2 specs (unless it was a genuine X2) as other combo's would go better & an X2 clone would be worth the same as an 'average' worked 186, because serious buyers would want an X2 engine number...?
#6 Posted : Tuesday, 8 May 2007 7:45:22 AM(UTC)
Dr Terry .If the X2 heads and dissys were modified is there a differant part number for them or is there any other way to id them as being X2.It time for a clean up and Id rather not get rid of something I may need later.While I am asking about the X2. Di
