bazza30555 Offline
#1 Posted : Monday, 7 May 2007 5:19:03 AM(UTC)
bazza30555
Is there any chassis or part no's stamped on a HK monaro subframe. Replacing old rusted one with HT. thanks.
#2 Posted : Monday, 7 May 2007 6:12:06 AM(UTC)
No. But HT is different from HK, and there are two different HK subframes. None of this matters if originality isn't your concern.
If we all had the same (good) taste, who would buy all the Fords
hk350 Offline
#3 Posted : Monday, 7 May 2007 7:47:31 PM(UTC)
hk350
What's the difference between the subframes?
Cheers.
#4 Posted : Monday, 7 May 2007 11:09:56 PM(UTC)
Early HK are smooth on the driver's side where the LHD battery goes, later HK have a notch so LHD vehicles' battery can be mounted on the RH side. HT and HG have outriggers to mount the gearbox crossmember on to, HK's have the crossmember bolted to the fl
#5 Posted : Monday, 7 May 2007 11:35:49 PM(UTC)
Hi Byron.
AFAIK both LHD & RHD HK/T/G have their battery in the same place. All the battery & starter lead part numbers for LHD & RHD are the same.
I think the reason behind the notch was to do with taking up excess metal in the metal-pressing proce
#6 Posted : Tuesday, 8 May 2007 3:46:41 AM(UTC)
Again you learn something new everyday. I put 2 and 2 together and got 5! The prseeings are basically the same though, so I suppose it's an easy mistake to make.
#7 Posted : Tuesday, 8 May 2007 7:12:44 AM(UTC)
Thanks guys. My monaro was delivered on 24-12-68 and the only differences I can pick is the extra brackets besides the headlights and the out riggers which I will be removing.
