Fred Offline
#1 Posted : Sunday, 26 November 2006 9:56:23 AM(UTC)
Fred
Has anyone ever heard of lowering the suspension on a HT subframe but lowering the Pivot shaft and redrilling the holes. I'm building a Plymouth ratrod and am using a HT Holden subframe. The chassis builder tells me buy doing this it will handle better would I need to have lower springs made and special shocks has anyone ever done this mod.
#2 Posted : Sunday, 26 November 2006 7:08:46 PM(UTC)
This is exactly how Holden facilitated phase 1 RTS on the LX Torana ie dropped the mounting point of the upper control arms. They only dropped it about an inch or so. I think this is what you are referring to.
Fred Offline
#3 Posted : Sunday, 26 November 2006 8:47:37 PM(UTC)
Fred
Yes thats what he suggested you can only lower it an inch as the tower bit that houses the top of the shock absorber bulges out.
So what would you think about the coil springs and shocks, I'm only using 6 cylinder coils as the motor sits back from the su
#4 Posted : Sunday, 26 November 2006 11:23:41 PM(UTC)
If you are simply lowering the upper control arm the 6cyl coils should be fine. All the new shocks available should be the same nowadays.
If we all had the same (good) taste, who would buy all th
#5 Posted : Monday, 27 November 2006 12:27:13 AM(UTC)
Met a bloke with a HK ute that said he'd done this mod & now it handles great, like it's on rails. Is it really as simple as drilling new holes...?
The Beige Hornet.
Fred Offline
#6 Posted : Monday, 27 November 2006 5:10:40 AM(UTC)
Fred
I'm running cycle guards so does anyone think it would be possible to cut and reweld the tower bit so it would be an inch lower, could this be done and still regain the same strenght as the origunal setup.
