Vintage Caravans Offline
#1 Posted : Thursday, 30 November 2006 6:10:22 AM(UTC)
Vintage Caravans
Hio Guys, I have a 308 of unknown origin, it has an engine number of QT277455, to me I would have thought it is out of a HQ, but can anyone shed any more light on it??????? or contradict me if I am wrong??
Matt
MSN Messenger = [email protected]
1962 EK Wagon - Chev SBC & T700, 1962 EK Sedan - Chev SBC & T700,EK Ute - V6 Buick & 5 speed = LOOKING FOR A 1962 EK VAN
#2 Posted : Thursday, 30 November 2006 6:54:05 AM(UTC)
HQ, non Statesman. trimatic pattern. Probably early enough for a US date code ie MDY
#3 Posted : Thursday, 30 November 2006 7:05:01 AM(UTC)
Vintage Caravans
will check that out when it arrives home, thanks for that, interesting it is a tri pattern cause it is bolted to a Chevy bellhousing, so I presumed it was a turbo one! goes to show you shouldnt assume anything!
Chers
Matt
MSN Messenger = earlyholden
#4 Posted : Thursday, 30 November 2006 8:06:04 AM(UTC)
Mmmm. Remember that HQ's used sequential numbers for all engines, so that HJ started somewhere after Qx500000, so to be a turbo block it has to be later than that. It is also very hard to convert a pre HJ block to the opposite bolt pattern. My guess is ei
#5 Posted : Thursday, 30 November 2006 5:39:47 PM(UTC)
Vintage Caravans
Thanks Byron, I am really intrigued now! it will be picked up on the 9th december, so I will see what the casting numbers are, and look to see if it has been modded?
Thanks for your info
Matt
#6 Posted : Sunday, 10 December 2006 6:40:19 PM(UTC)
Vintage Caravans
Hi Byron,
I have the new motor here and the casting dates are L212
So may I presume that it is the early USA numbering system, and it was made 21 Nov 72????
Cheers and thanks a million in advance
Matt
P.S. also checked the number it is as above so I
#7 Posted : Sunday, 10 December 2006 10:03:17 PM(UTC)
Yes, 21/11/72. Lines up with the engine number. But, the early blocks don't have casting material in the right place for conversion to TH pattern. Look at a HQ 253 or 308 block side by side with a later one and you'll see what I mean. So i don't know how
#8 Posted : Monday, 11 December 2006 5:33:01 AM(UTC)
Vintage Caravans
HMMMM me niether, so I will be ripping it out of the truck next weekend, and splitting it from the bellhousing so hopefully that will make for interesting viewing, should this motor be running a WW Stromberg??? or should it have a four barrel??? it looks
#9 Posted : Monday, 11 December 2006 6:05:57 AM(UTC)
Rochester Quadrajet 4BBL.
Intoit Offline
#10 Posted : Monday, 11 December 2006 6:12:05 AM(UTC)
Intoit
So how do you know by the number it is a trimatic block ? I had a 308 with no. QT276736 , it was a turbo block . Just curious .
Cheers ,
Shawn
--------------------Go Hard Or Go Home
Edited by user Monday, 11 December 2006 6:29:38 AM(UTC)  | Reason: Not specified
#11 Posted : Monday, 11 December 2006 7:04:08 AM(UTC)
The early 308s only had meat in the right places to suit a trimatic/aussie pattern, while later blocks had extra meat to suit both.
Byron can probably tell by the engine number sequence (and cast date!) approx what month/year any HQ-WB motor is (just l
#12 Posted : Tuesday, 6 March 2007 8:45:31 PM(UTC)
eng no. Q83384P 308
#13 Posted : Tuesday, 6 March 2007 10:02:23 PM(UTC)
Hi mick v.
QxxxxxP is a Queensland police number.
Block may have been stolen and recovered or may have come thru spare parts as a replacement, with no number stamped.
Dr Terry.
hqGTS2door Offline
#14 Posted : Monday, 12 March 2007 7:18:03 AM(UTC)
hqGTS2door
hey guys just wanting to no about sum engine numbers like when they wher made
1st QR616606
2ND QT383694
THANKS GUYS
#15 Posted : Monday, 12 March 2007 7:36:00 AM(UTC)
QR616606 is a 253 out of a HJ - could be any HJ that had a 253 option.
QT383694 is a 308 from a HQ - any HQ except for a Statesman.
If we all had the same (good) taste, who would buy all the For
hqGTS2door Offline
#16 Posted : Monday, 12 March 2007 7:52:48 AM(UTC)
hqGTS2door
SO HOW DO YOU TELL? HOW DO YOU NO THE 1ST 1 IS HJ?
WHAT PART OF THE NO: MEENS WHAT
#17 Posted : Monday, 12 March 2007 4:38:06 PM(UTC)
There were about 500,000 HQ's made and engines are sequential starting at Qx1001 (or thereabouts).
Q means engine/sump originated in HQ. R means high comp 253, T means 308.
If we all had the s
74HJLS Offline
#18 Posted : Monday, 12 March 2007 9:07:25 PM(UTC)
74HJLS
Just a small point, I think I remember 308 engines in Bedford trucks with 2 barrel carbys on them. I could be wrong though.
Pete.
Pete.
hqGTS2door Offline
#19 Posted : Monday, 12 March 2007 10:28:13 PM(UTC)
hqGTS2door
MY GTS IS A 10/71 SO DO YOU NO WHAT ENG NO:'S STOPED AT THE END OF 10/71 OR THER ABOUTS IM GOING TO RING NSW TODAY AND ASK WHAT ENG NO: THER HAVE ON THE P.C'S
hqGTS2door Offline
#20 Posted : Monday, 12 March 2007 10:49:29 PM(UTC)
hqGTS2door
I RANG NSW AND IT WAS THER BE FOR THEY GOT PC'S SO THEY DID NOT HAVE ANY INFO.
