hi does anyone know if the HQ ever came out with a factory heated rear window, or did they first appear in the HJ? If not, could a retrofit be organised, say a HJ-HZ Statesman heated rear window into an HQ Statesman? cheers frank
Option C49 (heated rear window) appears to have only been available from the HJ series onwards but my information only covers Monaro's and not Statesmans so this may not be completely accurate.
I would imagine it to be a simple task to fit a HJ-HZ rear
Over time I have had few HQ sedans. None had this option and the screen was bare. However there was a kit you could stick on yourself.
And yes I do believe the HJ was the first one to get it, and yes the HJ ones should fit. I just never bothered to se
It may not have been an option for Australian vehicles, but sorry to disappoint you guys, my Export HQ Chev Statesman has a factory fitted rear window heater. Just went out to the garage to check, the switch is on the bottom right hand side of instrument
OZ Chev,
Looks like we are BOTH right. Heated rear window was never an option in the standard body car (Belmont-Prem or Monaro). However, it was optioned in for the Statesman deVille and Stato L6 & V8. Thats models 81469, 81569, and 81669. Four part nu
John, It really is quite amasing to find the options to the export models as standard features over the local market products. I think my HQ has everything GMH had to offer. Whoever thought the HQ would have had a 12 Bolt diff fitted from the factory, I d
thanks guys - appreciate your efforts, i had a distant memory of seeing a pic of the dash rocker switch with the wording "heated rear window" ..! just need to find a switch now ...
Hi Guys.
Just to confirm that the HQ Statesman had the heated rear screen as a factory option for the Australian market in the '73 & '74 HQ series.
The SWB cars, Kingswood, Premier, Monaro etc did not get this option until HJ.
Dr Terry |
Joined: 2/03/2005(UTC) Posts: 451  ![Australia Australia]() Was thanked: 15 time(s) in 14 post(s)
David Ryan at Rare Spares 03 9 3054000 can help with rear screens for HQ's.Heated,plain,tinted etc.
