#1 Posted : Tuesday, 5 December 2006 6:58:21 AM(UTC)
One instant she runs like a dream, the next start, hard to start, it won't idle, misses, surges, cuts out.
Cleaned injectors, new fuel filter, new HT leads, new rotor button, fuel tank drained and cleaned, fuel pump tested.
Stumped. has anyone had similar problem?
sly376 Offline
#2 Posted : Tuesday, 12 December 2006 8:59:15 AM(UTC)
sly376
Try cleaning out the throttle body & idle stepper motor with throttle body cleaner (can't remember if they have one) Another thing it could be is a voltage drop to the ignition system or a bad vacum leak.
sly376 Offline
#3 Posted : Tuesday, 12 December 2006 9:02:21 AM(UTC)
sly376
Oh one other thing if I remember correctly those XE XF multi point fuel injection motors run like crap even if you have an oil leak or dip stick is not in properly as their a sealed system. Their air flow meters also play up.
#4 Posted : Tuesday, 12 December 2006 11:00:59 PM(UTC)
I had a similar problem with my old EFI XE. Turned out to be the coil had gone a bit intermittent.
#5 Posted : Friday, 6 July 2007 4:39:11 AM(UTC)
Check that the hose clamps inside the fuel pump are tight
This page was generated in 0.234 seconds.
