xp
camlj Offline
#1 Posted : Thursday, 7 December 2006 4:09:04 AM(UTC)
camlj
just bought an xp rolling shell after being a holden man for quite some time. just couldn't resist the shape and style. can you blame me? has a c4 gearbox in it and set up for a 351 windsor. just wondering how the c4's go behind a bit of grunt and if they're any good? any other suggestions maybe? also after most bits for motor and car. any help much appreciated. thanks.
Munromad2004 Offline
#2 Posted : Thursday, 7 December 2006 5:31:14 AM(UTC)
Munromad2004
I believe C4's are a very highly regarder transmission and can be beefed up to handle quite decent horsepower.
I will be using one behind the 351 in my XB Coupe eventually.
As long as the box is in good condition I think it would handle a 351W quite w
camlj Offline
#3 Posted : Thursday, 7 December 2006 9:01:34 AM(UTC)
camlj
also this might seem a stupid question but will a nine inch diff from a coupe fit into a sedan no hassles? i presume it would just thougth i'd double check. i can get my hands on one in average condition. not sure what centre's in it and what condition th
#4 Posted : Thursday, 7 December 2006 10:07:25 AM(UTC)
Munromad2004
Yep, bolts straight in. If you can get a nine inch for $300 you've scored well although if it needs rebuilding you can at least double that price.
The cheapest way to get one these days is to buy an ZF/ZG Fairlane (351) and wreck it.
#5 Posted : Saturday, 9 December 2006 2:52:33 AM(UTC)
thanks munromad for all your help. one more question though.. been ringing around looking for a 351 and some people have told me that i'll have a bit of a problem with the exhaust manifold. for simplicity is it worth just getting a 302 or is fitting a 351
#6 Posted : Saturday, 9 December 2006 4:48:11 AM(UTC)
289 and 302 windsor fit easy into XPs bit clevelands dont fit cause clevelands are too wide and hit on the towers and that is the same for 351 windsors
#7 Posted : Saturday, 9 December 2006 7:26:23 PM(UTC)
sorry didn't quite understand. will the 351w will hit the towers as well or will it fit easily? how would you go about fitting it? is it just a case then of different engine mounts or a bit more complex than that?
#8 Posted : Sunday, 10 December 2006 4:58:48 AM(UTC)
A 351 windsor will hit the towers and you have to modify the towers
#9 Posted : Sunday, 17 December 2006 11:52:27 PM(UTC)
351 windosrs fit but totally custom pipes are needed and are expensive. i have an xp sedan and an xp ute and all three of them run 302 windsors. they are a great engine and i even have 450hp at the flywheel in the ute. if you wanna see fotos or anythgin g
