tanart Offline
#1 Posted : Friday, 8 December 2006 1:13:49 AM(UTC)
tanart
Did all HK GTS come with dual horns or were these an option? Was there a difference between series 1 or series II?
#2 Posted : Friday, 8 December 2006 1:23:09 AM(UTC)
yes dual horns standard same as premier etc.
#3 Posted : Friday, 8 December 2006 1:44:40 AM(UTC)
Hi tanart.
cloudy has answered the horn question, but what is a series II HK GTS. Are you differentiating '68 production from '69 or are you talking about the 1st and 2nd type 327 engines, which weren't seen in a normal HK GTS anyway.
Dr Terry.
tanart Offline
#4 Posted : Friday, 8 December 2006 10:07:21 AM(UTC)
tanart
Sorry guys i should have made it more clear. Did the HK GTS '68 come with single horn or dual horns?
#5 Posted : Friday, 8 December 2006 4:02:10 PM(UTC)
the question has been awnsered ,all GTS cars have twin horns
#6 Posted : Friday, 8 December 2006 8:24:00 PM(UTC)
Some, at least some HK have a horn relay mounted near the horns. It is hard to get.
#7 Posted : Friday, 8 December 2006 11:59:57 PM(UTC)
This was with the extra high note package.
GTS was not fitted with this.
Warren
#8 Posted : Saturday, 9 December 2006 12:28:32 AM(UTC)
Hi Warren, do you mean when say a Kingswood was upspecced and the horns are the same (H,L)? Or is there a difference in the horns? It makes me wonder why the GTS/Prem didn't need the relay? Fuse rating maybe?
#9 Posted : Saturday, 9 December 2006 9:18:15 AM(UTC)
Relay for extra high note, if high note optioned on Kingswood then no relay.
Warren
#10 Posted : Saturday, 9 December 2006 9:33:06 AM(UTC)
Hi Warren, do you mean there is a L, H, and Xtra High? Reason I ask is I had a HK 186S Opel Kingswood, all factory, (Console, discs, Kingswood pattern bucket seats with cloth inserts) with twin horns and relay. So this would have had Low and XH? Or H & XH
#11 Posted : Saturday, 9 December 2006 9:50:00 AM(UTC)
Actually I take some of that back. The car had sustained a big hit in the front before I got it - the subframe had been welded across under the stone tray, so grill was a replacement. The 186S block had a weld through the rear ear on the same side. The fl
#12 Posted : Saturday, 9 December 2006 6:38:31 PM(UTC)
I've actually got some NOS HK Kingswood bucket seat squabs as you describe ie black with cloth insert. I bought them for the Sadlon vinyl surrounds for GTS seats.
If we all had the same (good) ta
#13 Posted : Saturday, 9 December 2006 9:40:41 PM(UTC)
yes there are two horn options, high note and extra high note.
Warren
This page was generated in 0.080 seconds.
