#1 Posted : Wednesday, 13 December 2006 7:51:49 AM(UTC)
I have an EL wagon and have the opportunity to aquire an AU series 1 with factory gas. I know the motors are basically the same so the gas system should swap over ok but will the gas tanks in the wheel well of the AU fit into the EL wheel well. Also, what other bits might I need to finish the job like the switches and guages. Can I just use the AU ones or will I need to get EL factory gas switches and guages?
Any advise will be most appreciated.
Bushbasher
#2 Posted : Wednesday, 13 December 2006 10:19:24 PM(UTC)
Well I just had a look under our BA wagon & judging by that the LPG tank will be under the floor of the AU wagon (where is this AU's spare wheel.
As you know all Falcon wagons from XR to EL have basically the same setup with the fuel tank being the s
Edited by user Wednesday, 13 December 2006 10:20:15 PM(UTC)  | Reason: Not specified
#3 Posted : Thursday, 4 January 2007 4:59:14 AM(UTC)
What was wrong with the AU was that it was a series 1, that was enough, haha.
I canned that idea in the end and just went out and bought an AUII Futura wagon with factory Tickford dual fuel. A much better idea me thinks. So now I have a 97 EL Futura C
