tanart Offline
#1 Posted : Thursday, 14 December 2006 9:19:49 PM(UTC)
tanart
i have a set of chev heads and need to know what they're off. The part number on them is 3917291. They have the double humps on the front of the head. Thanks
Sandman Offline
#2 Posted : Thursday, 14 December 2006 11:15:46 PM(UTC)
Sandman
Whats the casting number under the intake runner?
Should be 3 numbers.
Sound like old double hump Fuellies. Usually 1.94 & 1.5"valves, 64cc chamber, pressed in rocker studs. No accessory holes tapped in the front of the heads?
Edited by user Thursday, 14 December 2006 11:19:09 PM(UTC)  | Reason: Not specified
#3 Posted : Friday, 15 December 2006 9:09:18 AM(UTC)
64cc chambers, off:
'67-'69 302ci, 290hp, 2.02/1.6 valves.
'67-'69 327ci, 250hp, 275hp, 300hp, 1.94/1.5.
'67-'69 350ci, 325hp, 350hp, 2.02/1.6.
'67-'70 350ci, 295hp, 1.94/1.5.
If we a
tanart Offline
#4 Posted : Friday, 15 December 2006 10:03:20 PM(UTC)
tanart
were these ever used on the HK327?
#5 Posted : Sunday, 17 December 2006 7:04:09 AM(UTC)
No. But there is some confusion around HK type 2 heads. The blue parts manual lists part number 3958602 for the type 2 327. It is a 64cc, 1.94/1.5" valve fuel injection head for 1961-70 as fitted to higher performance engines. I think this was also the HT
ozchevy Offline
#6 Posted : Sunday, 17 December 2006 9:26:55 AM(UTC)
ozchevy
Byron,
I don't have any info on these 3958602 heads, and they are not listed in Sallee Chevrolet head lists either.
1968-69 (3917291) 350cu" 1.94 inlet 1.5 exhaust
1968-69 (3917290) 307,327cu" 1.72 inlet 1.5 exhaust
1969 (3927188) 307cu"
#7 Posted : Monday, 18 December 2006 9:43:25 AM(UTC)
I made a mistake above. Part number 3958603 is the 64cc HT head, not 3958602.
3958602 is the GM part number, not casting number. GMH also listed part number 3958603 for the type 1 HK 327 in the revised HK parts manual. Part number 3958602 is simply a sma
tanart Offline
#8 Posted : Monday, 18 December 2006 11:39:05 PM(UTC)
tanart
The chev heads cast number 3917291 have double humps.
#9 Posted : Tuesday, 19 December 2006 3:30:38 AM(UTC)
Do they have accessory holes in the ends?
ozchevy Offline
#10 Posted : Tuesday, 19 December 2006 6:47:18 AM(UTC)
ozchevy
3917291 are Double Hump heads, and no accessory holes are drilled as standard heads. 3927186 is as Byron say's also a Double Hump head, but these were called a Bowtie Head in the U.S
tanart Offline
#11 Posted : Tuesday, 19 December 2006 7:10:17 AM(UTC)
tanart
No accessory holes as ozchevy mentioned.
#12 Posted : Tuesday, 19 December 2006 7:29:06 PM(UTC)
I think that the 3917291 heads may have been the ones Des West got caught with. I remember hearing or reading somewhere that it was the casting marks and not the accessory holes that scutineers spotted. May be wrong though.
____________________________
