#1 Posted : Saturday, 16 December 2006 4:31:03 AM(UTC)
does anybody know if any other headlights will fit into the premier front panel or do i have to stick with the sealed beam type, as i have a light out and before i replace it i was considering my options.
thanks.
#2 Posted : Saturday, 16 December 2006 6:46:58 AM(UTC)
HZ have halogen lamps, so this is an option.
Warren
#3 Posted : Monday, 18 December 2006 9:11:39 PM(UTC)
The headlamps on your car a standard 7 inchers. They will interchange with just about any headlight. you regularly see crystal/jewell type headlights on eBay for around $50-$60 a pair new.
Often they are advertised as suiting a Nissan Patrol but i bel
#4 Posted : Tuesday, 19 December 2006 1:06:48 AM(UTC)
Hi Guys.
Jim, if ianb's HX has a Premier front, then the single 7" beams won't fit. The dual headlight (Premier) set-up use 2 x 5 3/4" beams on each side, one for lo/hi & one for hi only.
Dr Terry.
#5 Posted : Tuesday, 19 December 2006 1:54:28 AM(UTC)
as stated, i have the premier front, so twin light set up. i have been quoted about $200 for a halogen conversion that fits into the original rings, would i need to put relays into the light circuits, and if so, where is best, i will only run 55 low beam,
#6 Posted : Tuesday, 19 December 2006 11:34:29 AM(UTC)
Hi Ian,
Although they aren't THAT common nowadays, troll the wreckers yards that have older cars in stock and you may find a set of 5¾" halogen lights that'll suit your car.
Aftermarket ones are still available but will probably have to be ordered i
Edited by user Tuesday, 19 December 2006 11:38:22 AM(UTC)  | Reason: Not specified
#7 Posted : Wednesday, 20 December 2006 11:07:25 PM(UTC)
Ooops my bad I failed to read the word Premier sorry. I think that just about all cars with quad round headlamps in the 60's 70's & 80's had much the same setup with the 5 3/4 lamps. A couple of notable exceptions are Rolls royces & MK4 Zodiacs their quad
Edited by user Wednesday, 20 December 2006 11:11:29 PM(UTC)  | Reason: Not specified
