#1 Posted : Sunday, 17 December 2006 4:28:22 AM(UTC)
hello. does any 1 know where to get a set of bonnet locking pins like the origanal ones for xa,xb,xc. they have a chrome surrounding in the top of the bonnet. visible from the top. Im told they that they are an aftermarket xy bonnet locking pins but am not sure?
any ideas??
Paul351xb Offline
#2 Posted : Sunday, 17 December 2006 6:34:44 AM(UTC)
Paul351xb
The factory XY pin surrounds were plastic so what you are chasing must be an aftermarket item. I've never seen em myself. I think the only way your are going to get something like this is to get someone to machine you a set out of alloy and then polish
Munromad2004 Offline
#3 Posted : Sunday, 17 December 2006 10:16:15 PM(UTC)
Munromad2004
Try www.fomoco.com.au, www.superoo.com.au, www.grandtourer.com.au, www.xbfordfalconshop.com
The XA-XC type did not have the surrounds like the XY ones do.
fomoco or superoo above will have what you need. Also check out Rare Spares.
les Offline
#4 Posted : Monday, 18 December 2006 8:28:22 AM(UTC)
les
Paul351xb Offline
#5 Posted : Monday, 18 December 2006 10:45:04 AM(UTC)
Paul351xb
That's an XY kit, though it isn't showing the plastic bezels that sit on top of the bonnet around the pins. They must want extra for those. The metal parts you see, the cup sits under the bonnet, the plastic cup sits on top and the washer sits on the cu
Guest (6)
