#1 Posted : Thursday, 4 January 2007 7:55:02 AM(UTC)
hi can any one tell me how to wire up the active wire to the high beam circuit so when i dim the lights they will go off and vise versa when turning them on. I notice they all work off a negative system to turn the lights on , all the main wires are active all the time , thanks .
#2 Posted : Thursday, 4 January 2007 8:44:18 AM(UTC)
Just use the negative from the high beams to trigger one side of the relay coil, and hook the other side of the relay coil up to 12V+ (same feed as the lights will do).
