Fastlane
Holden Forums
Holden General Discussion
wiring driving lights to vr commodore
hi can any one tell me how to wire up the active wire to the high beam circuit so when i dim the lights they will go off and vise versa when turning them on. I notice they all work off a negative system to turn the lights on , all the main wires are active all the time , thanks .
Just use the negative from the high beams to trigger one side of the relay coil, and hook the other side of the relay coil up to 12V+ (same feed as the lights will do).
Fastlane
Holden Forums
