wannabe51 Offline
#1 Posted : Monday, 14 May 2007 7:20:15 PM(UTC)
wannabe51
I have fitted a 308 to my tonner and when I started it there was no oil pressure. This motor was running sweetly when I removed it 14 months ago and has not been touched at all since.
Pulled off the oil pump and found no oil in there. Blew ait through the oil pick-up port and could here oil bubbling so assumed sump pick-up is all in place. Can anyboby help with advice on the problem.
regards Dave.
ED57FE Offline
#2 Posted : Monday, 14 May 2007 11:57:58 PM(UTC)
ED57FE
could be a leak on the oil pick up to block face.
did you try priming the pump by filling thru the sender hole with oil?
that's how i prime my pump, some people pack them with grease but the JP instructions said not to do this, rather fill the pump
#3 Posted : Tuesday, 15 May 2007 3:17:57 AM(UTC)
Thank you for your advice. I will try priming through sender hole. This may sound silly but would I do this with the motor stopped or running?
kind regards
#4 Posted : Tuesday, 15 May 2007 3:23:37 AM(UTC)
Definitely stopped
klompy Offline
#5 Posted : Thursday, 17 May 2007 4:09:52 AM(UTC)
klompy
I have just had the same problem.Took the sender out and filled with oil 4 times ,no go.Took the pump of and filled with grease, refitted and filled filter with oil.Restarted the engine and instant oil pressure.Cheers.
#6 Posted : Thursday, 17 May 2007 9:18:05 PM(UTC)
Thanks for the advice, I may now go straight to the grease option.
regards Dave
This page was generated in 0.104 seconds.
