#1 Posted : Wednesday, 17 January 2007 6:32:20 AM(UTC)
G'day.
I'm thinking of installing an EA-BA fuel injected six in an XP ford sedan.
Not sure if it will fit or what mods i will have to do past updating the wiring loom.
I'm a holden bloke and have no idea about what ford motor fits in what.
Will a newer gearbox/motor combo need modifications done specifically to the undercarriage/firewall/chassis etc or just bolt in as is?
Mr Ker
#2 Posted : Wednesday, 17 January 2007 10:29:01 PM(UTC)
This would be a good swap. The EA-ED 3.9/4.0 engines use the same engine mounts as every other 6 cylinder Falcon from about XA onwards. EF's onwards use different mounts but the earlier mounts will bolt to the later engine.
There are two probable hu
Edited by user Wednesday, 17 January 2007 10:30:19 PM(UTC)  | Reason: Not specified
