T-note Offline
#1 Posted : Wednesday, 17 January 2007 8:24:45 PM(UTC)
T-note
OK so I need a new floor in the HJ cab (with HQ complete front), also it looks as though the inner and outer sills are shot to pieces (as are a couple of the cab mounts). I have been given a WB ute shell with very little rust, I am thinking of putting the tonner cowl and rear quarters on the WB, I figure there would be less work in swapping the rear quarters than patching up the HJ floor, sills and cab mounts?
I have already replaced the HJ chassis due to rust, so there will probably be alot more under what looks like a reasonably recent paint(and bog) job
Has anyone here done anything similar and maybe could lend a few words of experience, advice or opinions?
Cheers all,
Terry
Edited by user Wednesday, 17 January 2007 8:35:33 PM(UTC)  | Reason: Not specified
#2 Posted : Wednesday, 17 January 2007 10:50:55 PM(UTC)
It looks daunting, but removing the ute quarters and tray isn't that hard. In the end the only difference between a HQ ute cab and a HQ tonner cab is the quarters, sill length, the piece under the rear window and the two infill pieces between the back of
T-note Offline
#3 Posted : Thursday, 18 January 2007 6:38:55 AM(UTC)
T-note
Thanks Byron, sounds pretty straight forward with the rear. The WB cowl has had one corner section removed, can I just swap the HJ corner sections rather than the whole piece? , as for the HJ it has had an nissan LD28 and 5spd put in, how do I differentia
#4 Posted : Thursday, 18 January 2007 5:25:19 PM(UTC)
If it's a WB cab it will already have HJ-HZ dash mounts so there is no need to change anything. You can still run a HJ dash (which is basically the same as a WB) by using a HX or HZ harness. A HJ cab is easily picked from a HQ by the big plug on the firew
T-note Offline
#5 Posted : Friday, 19 January 2007 1:35:06 AM(UTC)
T-note
Thanks really appreciate the help
