#1 Posted : Thursday, 18 January 2007 2:35:46 AM(UTC)
are all 253 308 red and blue heads the same and interchangeable? cheers
#2 Posted : Thursday, 18 January 2007 3:58:56 AM(UTC)
253 and 308 are identical for the same model and ADR levels, with the exception of the LH SLR5000 with L34 option and the 5 litre engines in some VH Commodores with HDT big valve heads. I've left out any VK examples as there is no 253 engine. Apart from t
JBM Offline
#3 Posted : Thursday, 18 January 2007 5:03:47 AM(UTC)
JBM
Which heads have the EGR ports? Only the blue heads?
James
#4 Posted : Thursday, 18 January 2007 5:04:22 PM(UTC)
ADR27A red heads too, but not always used for EGR as some manuals had no EGR valve.
#5 Posted : Friday, 19 January 2007 2:27:59 AM(UTC)
whats egr and whats an egr valve? cheers and thanks
#6 Posted : Friday, 19 January 2007 6:52:19 AM(UTC)
Exhaust Gas recirculation. Part of ADR27A pollution requirements introduced in early 1976 on passenger cars and derivatives. Basically exhaust gas is redirected to the inlet manifold at certain vacuum and temperature conditions to lower exhaust emissions.
crowe Offline
#7 Posted : Saturday, 20 January 2007 12:42:35 AM(UTC)
crowe
If your doing up a Blue 253 then the existing heads for gas flow would be ok? reasoning- the 308 are the same heads but the 253 about 20% smaller motor and gas flow so plenty big enough?
#8 Posted : Saturday, 20 January 2007 3:34:27 AM(UTC)
Yes. You shouldn't ever touch ports or valves on a 253. You rarely need to touch them on a 308 for street use.
Edited by user Saturday, 20 January 2007 3:37:01 AM(UTC)  | Reason: Not specified
