Hi I have an hq rev counter it has on the back a switch for 6 or 8 and 2 prongs with earth and coil on them.. Can any one tell me how I can test it to see if it goes??
Can I test it on a 4 cylinder cortina as my V8 has an HEI dizzy 350 chev and the coils are in the cap..
I need to know if its working so I can place a feed back on an auction I brought it from
Any advice appreciated Keith
If its not broke it will be soon |
Thanks: 1 times Was thanked: 638 time(s) in 599 post(s)
Any engine will run it. Switch it to 8cyl and double whatever the revs say for a 4cyl. A HEI should run it - the unused pin on the side of the cap should drive a tacho. It did in my HJ.
_______________________________________________________ If we all |
The prong that says earth can I earth it any where?/ and the one that says coil on a normai car do I put that on the postive on the coil??
-ve.
