prem Offline
#1 Posted : Saturday, 20 January 2007 2:51:26 AM(UTC)
prem
i am running a 308 with a supra 5speed and a 2.78 10 bolt is this the the right choice or would it be better running a 3.08 or something else,,,,with it being able to run best at all times driver eg ,right through the speed range
#2 Posted : Saturday, 20 January 2007 3:33:31 AM(UTC)
Not a great choice of diff for a 5speed. 3.36 or 3.55 would be a better choice. 3.36 with a 0.85: 5th gives you an effective diff ratio of about 2.85:1 in top gear. 3.55 equates to about 3:1. With the 2.78 you are looking at about 2.36:1. By effective dif
Mr.Jones Offline
#3 Posted : Saturday, 20 January 2007 11:30:40 AM(UTC)
Mr.Jones
Have to agree with Byron, I had a supra w/3.36 behind an inject 304 was fantastic on the hway, great for passing road trains 1st was a little short but you cant have every thing.
Cheers Leroy
Voltaire
prem Offline
#4 Posted : Monday, 22 January 2007 5:30:58 AM(UTC)
prem
what rpm are you sitting on with the 304 in 5th on 1ookph,what can i get a 3.36 center out of mine is a 10 bold in a hz prem
thanks boys
Mr.Jones Offline
#5 Posted : Tuesday, 23 January 2007 7:06:15 AM(UTC)
Mr.Jones
My speedo never worked but was about 2700. 3.08 w/t700 is usually 2200.
Go to your local wreckers and ask. HX & HZ 253 4speed kingers are usually fitted w/3.55 or 3.36 gears, you are better off getting the whole diff and fitting that.
Voltaire
prem Offline
#6 Posted : Saturday, 24 February 2007 7:42:22 PM(UTC)
prem
so what will it be with a 3.36
Mr.Jones Offline
#7 Posted : Sunday, 25 February 2007 12:49:40 PM(UTC)
Mr.Jones
Using gearcalc worked out to be 2600 @ 110 w/ 235/65/14
hope this helps
Leroy
Voltaire
